Shows the status (enabled or disabled) of the switch's USB port.
| usb | Specifies USB port on switch. |
N/A.
The enable/disable switch usb commands require a reboot to take effect. This is reflected in the output of this show command:
# show switch usb USB port: Enabled # disable switch usb This setting will take effect at the next system reboot. # show switch usb USB port: Enabled (Disabled after the next reboot)Or in the same output, you can add:"After disabling usb using 'disable switch usb' output will be like this:# show switch usbUSB port: Enabled (Disabled after the next reboot)
The following example shows the switch's USB port status:
This command was first available in ExtremeXOS 22.3.
